Hello Qing
Apply a Mesh Method called Sweep. The source face is one side of the thickness. The Sweep Elements can be set to number of divisions.
If you Clear Generated Data on the Mesh in Workbench, then do File, Save, then do File, Archive, the archive file size will be reduced.
