Are the plates solid elements or shell elements?
If the plates are solid elements, then you need to have four quadratic or eight linear elements through the thickness. A single solid element is stiffer than multiple solid elements through the thickness. That will shift the curve closer to the lab curve.
What part of Australia are you in?
