DrAmine
Mass Flow rate is your input so you need to know it. If you do not know it but you know the amount of mass you want to add into your system you can turn on transient particle tracking and provide the mass as input instead of mass slow rate.
For steady state particle tracking the only one input and correct input is to have mass flow rate as one has a continious stream :)
