July 16, 2021 at 9:46 am
Good Morning Rob
Sorry for the late reply
So, as mentioned, our case involves a multispecies UDRGM with properties of the fluids defined via lookup tables.
After loading the case into the 2021 version we get the following message:
You can execute multiphase default changes for an old case file via the following text command:
solve/set/multiphase-numerics/default-controls
We don't know exactly what that means.
Also, when loading the UDFs we get the following warnings, which may be important:
cl : Command line warning D9024 : unrecognized source file type '..\..\src\interpolate.h', object file assumed
cl : Command line warning D9027 : source file '..\..\src\interpolate.h' ignored
cl : Command line warning D9024 : unrecognized source file type '..\..\src\lookup.h', object file assumed
cl : Command line warning D9027 : source file '..\..\src\lookup.h' ignored
UDRGM_lookup.c
# Generating udf_names.c because of makefile UDRGM_lookup.obj
Can you tell us if we need to change our scripts in order to read the header files?
I attach the whole TUI print as well as our case dat and UDFs.
Thank you very much for your help
UDRGM_lookup.c
