On the pressure outlet boundary condition panel there's a section for backflow properties, ie if flow comes back in what is it's temperature & pressure. Set these to an appropriate value or extend the domain to avoid the issue.
Note, setting an inlet velocity and recording the pressure loss tends to be a quicker solution than pressure in & out.
