June 2, 2021 at 10:44 am
I am trying to create a 2 simple models of
Case 1: 5km circular pipe in which the surface temperature is around 90 Degree Celcius and the fluid inlet temperature is 30 Degree Celcius. I would like to view the temperature contour across the circular pipe.
Case 2: 5km circular pipe with 1/4 of the pipe insulated from the surroundings and the other 3/4 is exposed to 90 Degree Celcius. All conditions same as Case 1.
