June 2, 2021 at 5:30 pm
Hi RK
I run the same case with 120 cores, except the URF DPS = 0.5 (previous one is 0.9). So I thin URF of DPS may be not the issue. I will keep running this case to check whether the DPM iteration interval cause this. Thank you.
Lei
myid (87): Fatal signal raised sig = SIGSEGV
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0() [0x266a6dc]
/lib64/libpthread.so.0(+0xf5d0) [0x7f9ae923b5d0]
/lib64/libc.so.6(+0x39acd) [0x7f9adc72cacd]
/lib64/libc.so.6(+0x39bb7) [0x7f9adc72cbb7]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0() [0x26677fe]
/lib64/libc.so.6(__sched_yield+0x7) [0x7f9adc7d5d47]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libmpi.so.12(PMPIDI_CH3I_Progress+0x230e) [0x7f9ada4a3b4e]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libmpi.so.12(+0x29cc63) [0x7f9ada607c63]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libmpi.so.12(+0x1108d4) [0x7f9ada47b8d4]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libmpi.so.12(+0x10ff40) [0x7f9ada47af40]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libmpi.so.12(MPI_Barrier+0x63d) [0x7f9ada47eedd]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/mpi_wrapper/lnamd64/intel/libmpi_wrapper.so(WMPI_Barrier+0x4d) [0x7f9aebee1c88]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/lnamd64/mpi/shared/libmport.so(mpt_mpi_gsync+0x16) [0x7f9aec1923f9]
/shared/software/ansys/v211/fluent/fluent21.1.0/multiport/lnamd64/mpi/shared/libmport.so(MPT_gsync+0xfd) [0x7f9aec13fcfe]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(par_fopen+0x15c) [0x1d2460c]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0() [0x229ec03]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(eval+0x1f6) [0x26823c6]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(PRF_Command_Start+0x1327) [0x683a47]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(PRF_Node_repl+0x2e) [0x684d9e]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(fluent_main+0x3dd) [0x69b6dd]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0(main+0x59) [0x6acc39]
/lib64/libc.so.6(__libc_start_main+0xf5) [0x7f9adc7153d5]
/shared/software/ansys/v211/fluent/fluent21.1.0/lnamd64/3d_node/fluent_mpi.21.1.0() [0x592111]
Lei
