peter_beshay
Dear Mr Rob I will try what you suggest, but that means changing the geometry and remeshing (you suggest adding like a baffle at the pipe inlet, right?
I am also trying to run now a case for just single phase water flow, to see the behavior of the pressure field with time.
Will update you when i get results.
Thank you so much for your help
