Yes. If the mesh was extruded from the inlet you might beable to split a zone out and change the surface types. Otherwise see if you can extrude the mesh "upstream" to make the extra section.
New Post - Reply To: Large Eddy Simulation for oil-water stratified flow – Pressure signal problem
