DrAmine
Ensure that every design point is starting from the Initialization you are taking and not starting from precious dp or cached data. In the "Solution" Cell in the WB, if you show the properties you will be able to change that. If you click on parameter Set and show the properties please let every DP to start / initiate from "Current".
I have a feeling that your solution is not deeply converged. For that reason if you now select one DP make it actual and run it: Which value is computed? Judge convergence of it.
