Lennart
Ok under which property do I change the initialization in "Solution"?
When I select one DP and click on Solution to run it and then calculate it, the calculation stops at 30 iterations, fluent closes and there's a message: "Collection has been changed. Enumeration operation may not be executed"
Where's the problem?
