It is better to remesh - if you are using WB/Mech., the use a quadratic mesh option (element order), or in apdl before meshing (AMESH command), issue type,type number for el. 281.
all the best
Erik
New Post - Reply To: Changing Element Type from Shell 181 to Shell 281 on existing mesh
