June 4, 2021 at 3:46 pm
Are you using a 4K display?
If not, can you try the following: close all Ansys Programs.
browse to:
%APPDATA%\Ansys
Rename the v211 directory to v211.old.
Try to run.
If you are using 4K:
Ultra High Definition (4K) Graphics Cards: Use of Ultra High Definition (4K) graphics cards may cause a number of cosmetic display issues (including enlarged or reduced text and incorrect positioning of option labels). These issues do not affect the functionality of the installation program.
For the issue you mentioned, please try the following workaround:
Automatic scaling and graphics window interactivity may not work correctly for4Kmonitors by default.
You can set the QT_AUTO_SCREEN_SCALE_FACTOR System Environment Variable equal to 0 to restore auto-scaling and graphics window functionality.
Please try the Windows System Variable listed above and let me know if this resolves the problem.
You can also try:
browse to:
%APPDATA%\Ansys
Try to run.
You can also try:
