DoodlerD
Thank you.
The units are fine, the command snippet is to activate ENFO, since it is missing in the solver worksheet. The value of forces are as described below. I'm running a set of benchmarks with Ansys after moving from a Nastran environment. I dont think Fz helps. However, I was able to work with the stress tensor and take the longer route. I'm not sure why ENFO does not work in my case.
