June 3, 2021 at 3:18 pm
Hi Rob, absolutely but I like to check out all the forums in case I miss anything :-) should I go through the other portal though??
The model is transient so I think I'm on the right path but not getting the outputs I thought I'd get.
I'm only putting in a few thousand particles as I'm just testing out the methods but I thought I'd get a non-zero results for the Coverage and Thickness. I do have a non-zero value for the Wall Film Velocity Magnitude.
(Please let me know if I should go through the commercial forums/avenues though)
Thanks
Thanks
