June 14, 2021 at 4:55 pm
FLUENT console
Opening input/output transcript to file "/home/iarauzo/tutorial_fluent/fluent-20210610-233419-55307.trn".
/ansys_inc/v211/fluent/fluent21.1.0/bin/fluent -r21.1.0 2d -pethernet -host -alnamd64 -t20 -mpi=intel -cnf=/home/iarauzo/.fluent.launcher.host -path/ansys_inc/v211/fluent -ssh -cx flutwin1:41787:42203
Starting /ansys_inc/v211/fluent/fluent21.1.0/lnamd64/2d_host/fluent.21.1.0 host -cx flutwin1:41787:42203 "(list (rpsetvar (QUOTE parallel/function) "fluent 2d -flux -node -alnamd64 -r21.1.0 -t20 -pethernet -mpi=intel -cnf=/home/iarauzo/.fluent.launcher.host -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "20") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/ansys_inc/v211/fluent") (rpsetvar (QUOTE parallel/hostsfile) "/home/iarauzo/.fluent.launcher.host") )"
Welcome to ANSYS Fluent 2021 R1
Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Nov 20 2020 18:46:04 ESTBuild Id: 10179
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "flutwin1" (unix).
/ansys_inc/v211/fluent/fluent21.1.0/bin/fluent -r21.1.0 2d -flux -node -alnamd64 -t20 -pethernet -mpi=intel -cnf=/home/iarauzo/.fluent.launcher.host -ssh -mport 155.210.150.19:155.210.150.19:40820:0
Starting /ansys_inc/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/bin/mpirun -f /tmp/fluent-appfile.iarauzo.57370 --rsh=ssh -genv I_MPI_FABRICS shm:tcp -genv I_MPI_FALLBACK_DEVICE disable -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_REDUCE 2 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_ADJUST_BCAST 1 -genv I_MPI_ADJUST_BARRIER 2 -genv I_MPI_ADJUST_ALLGATHER 2 -genv I_MPI_ADJUST_GATHER 2 -genv I_MPI_ADJUST_ALLTOALL 1 -genv I_MPI_ADJUST_SCATTER 2 -genv I_MPI_ADJUST_ALLGATHERV 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /ansys_inc/v211/fluent/fluent21.1.0/../../commonfiles/CPython/3_7/linx64/Release/python -genv FLUENT_PROD_DIR /ansys_inc/v211/fluent/fluent21.1.0 -genv KMP_AFFINITY disabled -genv LD_PRELOAD /ansys_inc/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/lib/libstrtok.so -genv TMI_CONFIG /ansys_inc/v211/fluent/fluent21.1.0/multiport/mpi/lnamd64/intel/etc/tmi.conf -machinefile /tmp/fluent-appfile.iarauzo.57370 -np 20 /ansys_inc/v211/fluent/fluent21.1.0/lnamd64/2d_node/fluent_mpi.21.1.0 node -mpiw intel -pic ethernet -mport 155.210.150.19:155.210.150.19:40820:0
IDHostnameCoreO.S.PIDVendor
n10-19flutwin210/256Linux-64174857-174866Intel(R) Xeon Phi(TM) 7210
n0-9flutwin110/256Linux-6457555-57564Intel(R) Xeon Phi(TM) 7210
hostflutwin1Linux-6455686Intel(R) Xeon Phi(TM) 7210
MPI Option Selected: intel
Selected system interconnect: ethernet
Multiple networks are configured on the system.
Ensure optimal choice of network interface and FLUENT communicator!
Cleanup script file is /home/iarauzo/tutorial_fluent/cleanup-fluent-flutwin1-55686.sh
Reading journal file /home/iarauzo/tutorial_fluent//_read_fluent_case_.jou...
> ;Journal file automatically created by Fluent!
/file read-case /home/iarauzo/tutorial_fluent/Converging_Nozzle.msh
Multicore SMT processors detected. Processor affinity set!
**HERE IT IS WHEN THE COMPUTER IS 30 MINUTES WORKING. This comment is not in console, it is mine**
Reading "/home/iarauzo/tutorial_fluent/Converging_Nozzle.msh"...
Buffering for file scan...
13805 nodes, binary.
616 nodes, binary.
27916 2D interior faces, zone1, binary.
56 2D velocity-inlet faces, zone5, binary.
252 2D wall faces, zone6, binary.
56 2D pressure-outlet faces, zone7, binary.
252 2D axis faces, zone8, binary.
14112 quadrilateral cells, zone2, binary.
Building...
mesh
auto partitioning mesh by Metis (fast) distributing mesh
parts.................... faces.................... nodes.................... cells.................... inter-node communication reduction using architecture-aware remapping: 78%
bandwidth reduction using Reverse Cuthill-McKee: 154/33 = 4.66667
materials interface domains zones axis
outlet
wall
inlet
converging_nozzle
interior-converging_nozzle
parallel Done.
Preparing mesh for display...
Warning: The use of axis boundary conditions is not appropriate for
a 2D/3D flow problem. Please consider changing the zone
type to symmetry or wall, or the problem to axisymmetric.
Done.
adjoint/mesh/report/
define/parallel/server/
display/plot/solve/
exitpreferences/surface/
file/print-license-usageviews/
display/plot/solve/
616 nodes, binary.
Building...
mesh
outlet
wall
inlet
converging_nozzle
parallel Done.
Done.
display/plot/solve/
display/plot/solve/
