June 4, 2021 at 6:28 pm
Assuming you know the axial blade chord and inlet, outlet beta angles for the blade with respect to the axial direction, you can directly create a BladeGen model using those values:
1.) Drag BladeGen from the toolbox onto the WB project schematic and double-click to open BladeGen
2.) Go to File->New BladeGen Model
3.) From the Initial Meridional Configuration Dialog Box, select Simple Axial. Set the axial chord by adjusting the leading edge and trailing edge Z values in the input boxes.
4.) Using the default mode (Prs/Sct), set the leading edge and trailing edge beta values in the input boxes.
Once in BladeGen, you can adjust/change the model as needed
