Ram Gopisetti
Make the energy balance disable and equate the Ref cycles to the Maximum number in the step control. By following this procedure, the solver will never check for the error in the energy and continues to calculate the them without stopping the run. Moreover, Drilling simulation needs large end time to run make sure you provide enough computation time and cores.
Cheers Ram
