1shan
"But the case that I showed here, the force is applied (or in other words, taken from the hole of a solid body) on one end of the line body, so shouldn't the other end of the same line body have the same value of shear force?" - Looks like your shear force is changing significantly from the left to the center. This cant be a cantilever case with point load at the end. Please check
Regards
Ishan.
