Good thinking: small models fail more quickly (or work) when you're learning.
If you want the pressure loading you'll need a y+ of as near 1 as possible. See where adaption gets you. Don't forget to increase the resolution over the shocks too as the wake has more of an effect on the flow than you may think.
