That looks about right. If you look closely at the force report you'll see a fairly small oscillation in the value. Add that to the residuals and it suggests the flow is still changing as there's a transient in there. My guess is that the jet is moving a bit (plot a contour every 10 iterations and watch the movie later). However, I doubt the overall solution is changing by enough to matter.
