The cell count is OK, as you'll be using around 255k cells per core. I'd also try and get the inflation around the corner (so slightly adjust the decomposition) otherwise you should be OK. You may also want to refine near the corner to reduce the aspect ratio if the flow separates: y+ is only part of what makes a good mesh.
