June 8, 2021 at 3:44 pm
For the real time both oil and water is used as continuous morphology in real experiment.
i will explain the real time experiment here.
At first water is put in separator with the help of pump and after minute oil is also pump into the separator. when pumping the water and oil lots of small and big bubble are form in the separator. which make lots of different in separation efficiency. this reason why i want to find the droplet distribution of water and oil.
i also attached the youtube video hopefully it will make you more understand.
" target="blank">3 Phase Separator/3PS Demonstration - YouTubei will explain the real time experiment here.
if you have any suggestion it will help me and save my time.
Thanks
