June 7, 2021 at 4:17 am
When I create 2 and 4 dents, the axes work quite normally. For example 2 dent with the function applied to the selected area ;
also the result of the region where only displacement is applied:
in both, the load was applied by choosing the surface normal. but when there are 4 and 6 numbers, very different results are seen due to the function variable. The dent areas are divided on the model and are applied to surfaces with a width of 2 mm and a length of 650 mm.
