Thank you for the reply. The bonded contact is in between the composite layers & thermoplastic solid. The composite layers are coming from ACP and the solid thermoplastic layer is coming from Mechanical Model like the picture attached below. Can I use a shared topology between two different models? If not, then how else can I overcome this issue? thank you!
