wcao
Hello
The answer to your question depends on if you have checked the "Non-Adiabatic Laminar Flame Speed" option in the "Properties" tab. If yes, the properties will be calculated with the PDF calculator automatically and tabulated as a function of f and radiation loss. While if not checked, it will use the adiabatic properties directly. Thank you.
