DrAmine
You need to build the areaInt in X, Y and Z Directions. You can use Sum reduction function and multiply the Static Pressure with the Facet Area in the appropriate direction. You get a vector and you can get its magnitude or scalar product with the direction to get the right magnitude in the requested direction. Integral of pressure is WRONG.
