DrAmine
Which time are you talking about? The time in the injection header and injection file? I still get the same behavior if I increase that time column to anything and this is expected. I am using 21R1. You can use the option STart fol-time in File" to start injection after certain time elapsed: the last column in the injection file will then be used.
