Do you mean this intersection?
Just turn off Thick Shells and Beams and you will see that intersection is not there. It is just a display artifact of Thick Shells and Beams. In reality, there is a single node at the center and some shell elements go across and other shell elements go down the center. There is no problem using shells in this situation.
