Karthik R
Administrator
Hello
You can perhaps modify the geometry to avoid these skewed elements in the first place. I'm assuming that there is sharp corner or edge which is causing these skewed elements.
Try to see if you can workaround this by creating a small surface instead of a single edge. Let us know if this helps.
Karthik
