June 21, 2021 at 10:32 am
Hi rjkosari
many thanks for your response.
Yes so the message is occuring in the AEDT message manager. All the HPC options are properly set and GPU is enabled (inc. for SBR+ solve as this is my design type) and the single GPU is added to the GPU column of the Analysis Config.
I have shared the outputs of the two command below, the smi command output is quite long, but here goes......
==============NVSMI LOG==============
Timestamp: Mon Jun 21 10:37:40 2021
Driver Version: 460.32.03
CUDA Version: 11.2
Attached GPUs: 1
GPU 00000000:81:00.0
Product Name: Tesla P100-PCIE-16GB
Product Brand: Tesla
Display Mode: Enabled
Display Active: Disabled
Persistence Mode: Disabled
MIG Mode
Current: N/A
Pending: N/A
Accounting Mode: Disabled
Accounting Mode Buffer Size: 4000
Driver Model
Current: N/A
Pending: N/A
Serial Number: 0325216044281
GPU UUID: GPU-a224c5a1-7d39-82c5-f1fa-7484bcb0e3a6
Minor Number: 0
VBIOS Version: 86.00.3A.00.03
MultiGPU Board: No
Board ID: 0x8100
GPU Part Number: 900-2H400-2700-030
Inforom Version
Image Version: H400.0201.00.08
OEM Object: 1.1
ECC Object: 4.1
Power Management Object: N/A
GPU Operation Mode
Current: N/A
Pending: N/A
GPU Virtualization Mode
Virtualization Mode: None
Host VGPU Mode: N/A
IBMNPU
Relaxed Ordering Mode: N/A
PCI
Bus: 0x81
Device: 0x00
Domain: 0x0000
Device Id: 0x15F810DE
Bus Id: 00000000:81:00.0
Sub System Id: 0x118F10DE
GPU Link Info
PCIe Generation
Max: 3
Current: 3
Link Width
Max: 16x
Current: 16x
Bridge Chip
Type: N/A
Firmware: N/A
Replays Since Reset: 0
Replay Number Rollovers: 0
Tx Throughput: 0 KB/s
Rx Throughput: 0 KB/s
Fan Speed: N/A
Performance State: P0
Clocks Throttle Reasons
Idle: Not Active
Applications Clocks Setting: Not Active
SW Power Cap: Active
HW Slowdown: Not Active
HW Thermal Slowdown: Not Active
HW Power Brake Slowdown: Not Active
Sync Boost: Not Active
SW Thermal Slowdown: Not Active
Display Clock Setting: Not Active
FB Memory Usage
Total: 16280 MiB
Used: 0 MiB
Free: 16280 MiB
BAR1 Memory Usage
Total: 16384 MiB
Used: 2 MiB
Free: 16382 MiB
Compute Mode: Default
Utilization
Gpu: 0 %
Memory: 0 %
Encoder: 0 %
Decoder: 0 %
Encoder Stats
Active Sessions: 0
Average FPS: 0
Average Latency: 0
FBC Stats
Active Sessions: 0
Average FPS: 0
Average Latency: 0
Ecc Mode
Current: Enabled
Pending: Enabled
ECC Errors
Volatile
Single Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Double Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Aggregate
Single Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Double Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Retired Pages
Single Bit ECC: 0
Double Bit ECC: 0
Pending Page Blacklist: No
Remapped Rows: N/A
Temperature
GPU Current Temp: 39 C
GPU Shutdown Temp: 85 C
GPU Slowdown Temp: 82 C
GPU Max Operating Temp: N/A
GPU Target Temperature: N/A
Memory Current Temp: N/A
Memory Max Operating Temp: N/A
Power Readings
Power Management: Supported
Power Draw: 28.42 W
Power Limit: 250.00 W
Default Power Limit: 250.00 W
Enforced Power Limit: 250.00 W
Min Power Limit: 125.00 W
Max Power Limit: 250.00 W
Clocks
Graphics: 405 MHz
SM: 405 MHz
Memory: 715 MHz
Video: 835 MHz
Applications Clocks
Graphics: 1189 MHz
Memory: 715 MHz
Default Applications Clocks
Graphics: 1189 MHz
Memory: 715 MHz
Max Clocks
Graphics: 1328 MHz
SM: 1328 MHz
Memory: 715 MHz
Video: 1328 MHz
Max Customer Boost Clocks
Graphics: 1328 MHz
Clock Policy
Auto Boost: N/A
Auto Boost Default: N/A
Processes: None
=============lspci -vnn|grep -a 12 output =============
I/O ports at 1120 [size=4]
I/O ports at 1124 [size=4]
0c:00.0 PCI bridge [0604]: Renesas Technology Corp. SH7758 PCIe Switch [PS] [1912:001d] (prog-if 00 [Normal decode])
0d:00.0 PCI bridge [0604]: Renesas Technology Corp. SH7758 PCIe Switch [PS] [1912:001d] (prog-if 00 [Normal decode])
0d:01.0 PCI bridge [0604]: Renesas Technology Corp. SH7758 PCIe Switch [PS] [1912:001d] (prog-if 00 [Normal decode])
0e:00.0 PCI bridge [0604]: Renesas Technology Corp. SH7758 PCIe-PCI Bridge [PPB] [1912:001a] (prog-if 00 [Normal decode])
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
10:00.0 Unassigned class [ff00]: Renesas Technology Corp. SH7758 PCIe End-Point [PBI] [1912:001b]
7f:12.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6fa0] (rev 01)
7f:12.1 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6f30] (rev 01)
7f:12.2 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 Debug [8086:6f70] (rev 01)
ff:12.0 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6fa0] (rev 01)
ff:12.1 Performance counters [1101]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 [8086:6f30] (rev 01)
ff:12.2 System peripheral [0880]: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 Debug [8086:6f70] (rev 01)
Many thanks
CUDA Version: 11.2
Attached GPUs: 1
MIG Mode
Current: N/A
Pending: N/A
Driver Model
Current: N/A
Pending: N/A
Minor Number: 0
MultiGPU Board: No
Board ID: 0x8100
Inforom Version
OEM Object: 1.1
ECC Object: 4.1
GPU Operation Mode
Current: N/A
Pending: N/A
Host VGPU Mode: N/A
IBMNPU
PCI
Bus: 0x81
Device: 0x00
Domain: 0x0000
GPU Link Info
PCIe Generation
Max: 3
Current: 3
Link Width
Max: 16x
Current: 16x
Bridge Chip
Type: N/A
Firmware: N/A
Fan Speed: N/A
Idle: Not Active
FB Memory Usage
Total: 16280 MiB
Used: 0 MiB
Free: 16280 MiB
BAR1 Memory Usage
Total: 16384 MiB
Used: 2 MiB
Free: 16382 MiB
Utilization
Gpu: 0 %
Memory: 0 %
Encoder: 0 %
Decoder: 0 %
Encoder Stats
Active Sessions: 0
Average FPS: 0
Average Latency: 0
FBC Stats
Active Sessions: 0
Average FPS: 0
Average Latency: 0
Ecc Mode
Current: Enabled
Pending: Enabled
ECC Errors
Volatile
Single Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Double Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Aggregate
Single Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Double Bit
Device Memory: 0
Register File: 0
L1 Cache: N/A
L2 Cache: 0
Texture Memory: 0
Texture Shared: 0
CBU: N/A
Total: 0
Retired Pages
Single Bit ECC: 0
Double Bit ECC: 0
Remapped Rows: N/A
Temperature
Power Readings
Power Draw: 28.42 W
Clocks
Graphics: 405 MHz
SM: 405 MHz
Memory: 715 MHz
Video: 835 MHz
Applications Clocks
Graphics: 1189 MHz
Memory: 715 MHz
Graphics: 1189 MHz
Memory: 715 MHz
Max Clocks
Graphics: 1328 MHz
SM: 1328 MHz
Memory: 715 MHz
Video: 1328 MHz
Graphics: 1328 MHz
Clock Policy
Auto Boost: N/A
Processes: None
Many thanks
