Sellera
I see, I noticed that is possible monitore the coordinates but for that it's necessary to use a Dinamic Mesh, and set up it for the hull right?(I can't plot using the actual configuration because it's not especified the point I want to monitore, right?)
I've tried but its necessary to use a doc.txt for that setup, how can I prepare that doc?
Thanks for your answer
