Thanks for your reply. The areas of the square blocks are the interfaces and go through the fluid chamber towards the +x direction. there will be no movement in the y and z-direction. here fluid will flow in the -ve x direction.
New Post - Reply To: How to set up the moving solid fluid interface with constant velocity?
