1shan
You could define the reference temperature in fluent under setup>reference values and use the same value for 'material field variable' in engineering data. The kind of constraints would depend on how the engine block is connected to rest of the components. The block must be bolted at some points right? You could insert a fix support at these points.
Regards
Ishan.
