Please check following in Ansys Meshing.
The min orthogonal quality should be above 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh.
First check the locations of the bad elements. Please see following video for the same.
Once you have locations, please check if you can improve mesh using different mesh sizing. Please see following video.
