1shan
What kind of constraint have you used? I think the edges where all 3 blades intersect should be fixed in all dofs. You could simply use a fixed support. Also duplicate the structural analysis and perform a modal analysis. This will help you identify any unconstrained motion. Not sure but the connection object in the first 2 images looks empty. Why have you used a contact tool if no contacts are defined?
Regards
Ishan.
