June 14, 2021 at 9:03 am
I still have not resolved the issues with the beam probes.
To check if the Springs are transmitting force appropriately to the lower module i added a lateral displacement to the upper module and compared this to the previous case which only had a vertical displacement.
The reactions certainly did change as you can see in the images below, but the probes are still reporting zero results.
Any assistance would be great.
Thanks Michael
