June 19, 2021 at 5:15 pm
Thank you and for your replies.
I checked the heat flux and it gives a considerable value. But I can not see any variation in temperature contours.
The ship is 186m long, 35 m beam, and 18 m in height.
I have used a volumetric heat source to the zone where the fire started and want to check the propagation of the fire. But when I run the simulation, there is no heat transfer through the ship. Temperature elevation can only be seen in the area where the heat source is applied. I have enabled coupled walls between bodies for conjugate heat transfer. But still, I cannot see the expected heat transfer through the ship to the water body.
What can be the reason for this?
Also in the contour chart, it is the same value shown for every color. why is that?
Looking forward to a reply from you.
Thank you!
Thank you!
