June 19, 2021 at 6:36 am
Please help me with this error, I don't understand this error
*GET_WALLSTRTFROMACTIITEM=TIME WALLVALUE=12.0436111
*********** Resuming The ANSYS db File from Modal Solution ***********
RESUME ANSYS DATA FROM FILE NAME=C:\Users\AYUSH JAISWAL\AppData\Local\Temp\WB_AYUSH JAISWAL_4816_2\wbnew_files\dp0\SYS\MECH\file.db
*** ERROR ***CP =0.922TIME= 12:02:37
Data file C:\Users\AYUSH JAISWAL\AppData\Local\Temp\WB_AYUSH
JAISWAL_4816_2\wbnew_files\dp0\SYS\MECH\file.db does not exist for
RESUME.
NUMBER OF WARNING MESSAGES ENCOUNTERED=0
NUMBER OF ERRORMESSAGES ENCOUNTERED=1
ERROR: Worker process(es) with rank(s) 3, 5 have encountered a FATAL error.
The information below was gathered from the file*.out output file(s).
Please review the worker process output file(s) listed below for more
details on this error.
Worker Process Output File .\file3.out:
*** FATAL ***CP =1.328TIME= 12:02:37
MPI error code = 2036473904 which translates to:
Other MPI error, error stack:
PMPI_Bcast(2667)....................: MPI_Bcast(buf=000000DDE8DF9820,
count=2, MPI_INT, root=0, MPI_COMM_WORLD) failed
MPIR_Bcast_impl(1804)...............: fail failed
MPIR_Bcast(1832)....................: fail failed
I_MPIR_Bcast_intra(2056)............: Failure during collective
I_MPIR_Bcast_intra(2043)............: fail failed
MPIR_Bcast_advanced(2135)...........: fail failed
MPIR_Bcast_intra(1599)..............: fail failed
Worker Process Output File .\file5.out:
*** FATAL ***CP =1.125TIME= 12:02:37
PMPI_Bcast(2667)....................: MPI_Bcast(buf=000000B3295F9A50,
I am getting this while running Random Vibration analysis.
RESUME.
