Greg Baethge
The transmission through a monitor is calculated using the component of the Poynting vector normal to its surface. So how the monitor is oriented, defines in which direction we calculate the power flow. For example, if you want to get the power flowing in the x direction, the monitor will have to be orthogonal to the x axis.
