Navya C
You can assign current to the moving conductor. If there is any issue with that, maxwell should generate an error wile validating the model before running the analysis.
With that said, I couldn't quite understand what your model is exactly.
Can you add some annotations to represent different parts in your model?
also, add some screenshots to show how you defined the band and excitations.
Regards
Navya
