Bolt Pretension is typically run in a 2-step solution.
Step 1 applies the bolt pretension load while the applied moments are zero.
Step 2 changes the bolt to Lock then ramps up the moments.
It's better to use File Archive to create a .wbpz file, which can be attached to these replies.
