June 21, 2021 at 12:08 pm
DP1 (which calculates):
Table of DP (after running calculations):
Message:
(DP 2) The Setup component in Static Structural for Design Point 2 requires user input before it can be updated. For instructions on how to address the cell in its current state, click the blue triangle in the lower right corner of the cell in the Project Schematic. Set the design point as current to see the state at the point of failure.
DP2 (which do not calculate)
It does not matter which geometry parameter I update - it does not calcualate. As you can see, only fixed support geometry is missing. In this case I modified whole structrure height, which does not change position of vertices
If anyone know how to fix this , please explain, I need to run this analysis for my diploma work :(
Message:
