June 22, 2021 at 2:35 pm
,and also, if you may, let me share a video uploaded by ANSYS YouTube channel which properly illustrate how to model a multilinear plastic material properties.
In this video, the data for the tensile strength test is inputted. But what if I have a structure which is going plastic deformation in compression? Will inputting the experimental data coming from the tensile test be enough for the solver, or do I need to add the data specifically from the compression test?
Plus, do I need to add the Tensile/Compressive Yield and Ultimate strengths as well before or after adding the tabular data for plastic strain (under multilinear hardening)? If not, then if I do so, will it create a problem for the solver?
I would be extremely grateful if you can answer these queries. Thank you :)
