June 24, 2021 at 10:19 am
That is a list of solutions from the solution list.
But the problem is omnipresent in every table: the quantities a sorted correctly only within the same order (of the integer part). The next order of the quantity does not follow the sorting order(direction):.
In the decrease-sorted example above, the higher order of the numbers is appended to the tail, instead of going in the head of the list.
In every version of HFSS I ever seen. I was surprised to find it again in 2021R1.
