Anadi_Mondal
I turned on gravity and see vapor and liquid temperature unchanged. Actually , I am expecting these ,the vapor and liquid should be at saturation(299.85K) temperature even after applying heat flux. This is the result after 7s.
I am expecting to plot a graph like below(LEFT SIDE) . Tw is the top edge temperature of surface_3(copper surface). The contour only gives phase temperature .However, how can I get copper surface(solid body) temperature?
I am suspecting an error at 'Named Selections'[RIGHT SIDE].What is the right way for naming A,B and C boundary? Here , both D and E domain are solid.
I need to apply heat flux at the bottom wall of domain D(copper surface).
Regards Anadi
