jasonsum25
Thanks Amine. As shown above, the epsilon curve in residual graph keep spike higher and higher. How can I identify the problematic region(s) (causing the residual not converging) after setting cell registers?
In the following photo, what range should I set for the velocity magnitude so that I can find out the error of my setup? Thanks a lot!
