June 30, 2021 at 1:18 pm
That is good - piezo are normally done in freq. domain using harmonic response.
For static use just d,exc,volt,100, and for transient, use a table called for instance voltexcite shown below (that varies with time) instead of a constant:
like this:
/PREP7
CMSEL,S,EXC,NODE
CP,NEXT,VOLT,ALL
ALLSEL,ALL
CMSEL,S,GROUND,NODE
CP,NEXT,VOLT,ALL
ALLSEL,ALL
/SOLU
KBC,1
*DIM,tbexc,TABLE,4,,,TIME
tbexc(1,0) = 0,0.0000011,0.0000022,0.000002225
tbexc(1,1) = 0, 100,0,0
*DIM,voltexcite,TABLE,31,1,1,TIME ! Time values
voltexcite(1,0,1) = 0.
voltexcite(2,0,1) = 2.5e-007
voltexcite(3,0,1) = 2.25e-006
voltexcite(4,0,1) = 2.5e-006
voltexcite(5,0,1) = 2.75e-006
voltexcite(6,0,1) = 4.75e-006
voltexcite(7,0,1) = 5.e-006
voltexcite(8,0,1) = 5.25e-006
voltexcite(9,0,1) = 7.25e-006
voltexcite(10,0,1) = 7.5e-006
voltexcite(11,0,1) = 7.75e-006
voltexcite(12,0,1) = 9.75e-006
voltexcite(13,0,1) = 1.e-005
voltexcite(14,0,1) = 1.025e-005
voltexcite(15,0,1) = 1.225e-005
voltexcite(16,0,1) = 1.25e-005
voltexcite(17,0,1) = 1.275e-005
voltexcite(18,0,1) = 1.475e-005
voltexcite(19,0,1) = 1.5e-005
voltexcite(20,0,1) = 1.525e-005
voltexcite(21,0,1) = 1.725e-005
voltexcite(22,0,1) = 1.75e-005
voltexcite(23,0,1) = 1.775e-005
voltexcite(24,0,1) = 1.975e-005
voltexcite(25,0,1) = 2.e-005
voltexcite(26,0,1) = 2.025e-005
voltexcite(27,0,1) = 2.225e-005
voltexcite(28,0,1) = 2.25e-005
voltexcite(29,0,1) = 2.275e-005
voltexcite(30,0,1) = 2.475e-005
voltexcite(31,0,1) = 2.5e-005
! Load values
voltexcite(1,1,1) = 0.
voltexcite(2,1,1) = 100.
voltexcite(3,1,1) = 100.
voltexcite(4,1,1) = 0.
voltexcite(5,1,1) = -100.
voltexcite(6,1,1) = -100.
voltexcite(7,1,1) = 0.
voltexcite(8,1,1) = 100.
voltexcite(9,1,1) = 100.
voltexcite(10,1,1) = 0.
voltexcite(11,1,1) = -100.
voltexcite(12,1,1) = -100.
voltexcite(13,1,1) = 0.
voltexcite(14,1,1) = 100.
voltexcite(15,1,1) = 100.
voltexcite(16,1,1) = 0.
voltexcite(17,1,1) = -100.
voltexcite(18,1,1) = -100.
voltexcite(19,1,1) = 0.
voltexcite(20,1,1) = 100.
voltexcite(21,1,1) = 100.
voltexcite(22,1,1) = 0.
voltexcite(23,1,1) = -100.
voltexcite(24,1,1) = -100.
voltexcite(25,1,1) = 0.
voltexcite(26,1,1) = 100.
voltexcite(27,1,1) = 100.
voltexcite(28,1,1) = 0.
voltexcite(29,1,1) = -100.
voltexcite(30,1,1) = -100.
voltexcite(31,1,1) = 0.
D,EXC,VOLT,%voltexcite%
D,GROUND,VOLT,0
like this:
/PREP7
CMSEL,S,EXC,NODE
CP,NEXT,VOLT,ALL
ALLSEL,ALL
CMSEL,S,GROUND,NODE
CP,NEXT,VOLT,ALL
ALLSEL,ALL
/SOLU
KBC,1
! Load values
D,GROUND,VOLT,0
