July 5, 2021 at 1:11 pm
Hi
not sure why that is. (try in excel to create three columns as you show above, add the correct time and voltage, and then copy and paste that into the voltage object you are showing above-not sure though because I never use these things)
If this does not work, I would suggest to do as explained and the commands posted in my previous post.
Also instead of writing the ansys apdl table as in the above linked post, we can have a csv file of the voltage excitation, and read that in to a table which is applied later to the model (see below for tread).
Thank you
Erik
Thank you
Erik
