Search AIS
Search Forum
Search Courses
Search Certifications
Search Knowledge
Search Marketplace
Search Ansys.com
FREE STUDENT SOFTWARE
Login
Learning Forum
Feed
My Posts
Help
August 3, 2021 at 2:58 pm
Guilin Sun
提取数据只要提取出来应该就没问题。至于结果是不是正确,那要你自己判断了,比如设置的边界条件是否正确?频域结果是否是信号彻底衰减后得到的?PML是否反射很小。你可以参考收敛性测试:
Convergence testing process for FDTD simulations ...
Guilin Sun
Cancel
Save Reply as Draft
Publish
Guilin Sun
Add Tags
Share to Feed
Share to Groups
Cancel
Save Draft
Publish
